Associate VLANs with an ACL
Associate VLANs with an ACL to apply filters to VLAN traffic.
A VLAN can be part of two different ACLs of different types: IPv6 and non-IPv6.
  • The ACL exists.
    enable
    configure terminal
  2. Add VLAN interfaces to an ACL:
    filter acl vlan <1-2048> <1-4059>
  3. Remove specified VLAN interfaces from an ACL:
    no filter acl vlan <1-2048> <1-4059>
Variable definitions
Use the data in the following table to use the filter acl vlan command.
Variable
Value
<1-2048>
Specifies the ACL ID.
<1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
